http://www.sportaviationonline.org/spor ... 1001/#pg38
Length: 32.5’
Height: 10.8’
Wing span: Tip Float down 48’/ Tip Floats up xx’
Wing area: 295 sq. ft.
Aspect ratio: 7.8
Wing loading: 20.3 Lb/sq. ft.
Power loading: 10.3 Lb/sq. ft.
Seats: 2 pilot, 4 passenger
Cabin width: 54”
Airfoil: GA35U-A315
Engines (2): Lycoming, IO-540 & LIO-540
Propeller: MT Propeller, 3 Blade, constant speed, feathering,
reversing.
Design Gross Weight: 6000 Lbs
Useful load (Typical): 1800 Lbs
Fuel capacity (Each side): Inboards tanks 40 Gals./
Outboard tanks 60 Gals.
Performance (Estimated):
Estimated Cruise Speed – 135 Knots at 65% power,
at 3000 ft MSL.
http://gweduc.netfirms.com/gweduck.com/index.shtml
Bye Luc
