Cela fais un temps j' ai découvert par le biet de Fs2004 cette belle machine que j ai acheter sur le site de coronado et j adore le volé, j aimerai savoir si d entre vous savez s il y en a au Québec, car j aimerai bien aller l essayé, car il étais un des premier avion d entrainement de l armée américaine et que le canada a participé a sa conception et sa fabrication.
Merci d avance a tous
189 mph (164 knots); cruising speed at 60% of rated 225 hp at 10,000 feet, 173 mph (150 knots); maximum permissible diving speed, 280 mph (243 knots). Both versions would afford an extremely high flight safety factor of 10 permitting unrestricted aerobatic maneuvers. Both aircraft weighed in at 2,900 pounds gross, and approximately 2,170 pounds empty. Both used a 225 hp Continental engine powering an 88-inch diameter Beech constant speed propeller, affording a rate of climb of 1,230 fpm at sea level, a sea level takeoff run of 780 feet, and a landing run at seal level of 330 feet. Wing span was 32 feet 10 inches with a length 25 feet 11 inches, a height 9 feet 7 inches; and total wing area including ailerons, of 177.6 square feet. In December of 1954 Beech delivered on the first T-34B trainer, just six months to the day from the date the contract was signed.
