Hélico
Hélico
Y en a tu un qui peut me dire à quoi ça sert? tout ce que je sais c'est que ça va sur un hélico
Serge :) :shock:
ULYSSE
Post by ULYSSE »
Bonjour Sierra,
Voici un élément de réponse trouvé sur le site suivant:
http://avia.russian.ee/theory/bell-407/cockpit.html
The engine instruments are arranged in two vertical rows just to the left of the flight instruments, with the three most important ones right next to the airspeed indicator and dual tachometer.
At the top is the torquemeter, which indicates directly how much power is being supplied to the rotor. This is your primary power setting instrument, and is affected directly by movement of the collective.
Next down is MGT, which stands for Measured Gas Temperature—the temperature of the stream of hot gas in the engine. While the torquemeter is your power setting instrument, MGT is your power limiting instrument: at higher temperatures and/or altitudes, you may reach limiting engine temperature before you have obtained all the torque you might like. In this case, you'll just have to be content with what power (torque) you can obtain. You'll notice a couple of red markings beyond the redline. The first, at 843 degrees, is a start limit; you should abort an engine start if MGT goes above this mark for more than a couple of seconds. The second, at 905 degrees, is an absolute limit beyond which any engine operation will be recorded immediately as an exceedance.
Désolé pour la version anglaise :?
Je pense que tu l'a trouvé Ulysse :D
Serge :D
reecky
Marque de l'avion: un jour
Post by reecky »
heeee
y a ti qqun qui va le dire a quoi y sert le bidule indicateur
Reecky
Mesurer la température dans la turbine je pense ?
Mon chef pilote vient de me dire que c'est pour mesurer la température des gaz d'échapement comme l'a suggéré Gaston.
MGT : Main Gas Temperature.
Bon bien merçi tout le monde :D m'a me coucher un peu moin niaiseux à souoir :lol:
Serge :D
c_gbcx
Marque de l'avion: Cessna XP2
Post by c_gbcx »
sierra wrote:Bon bien merçi tout le monde :D m'a me coucher un peu moin niaiseux à souoir :lol:
Serge :D
Bien non, il faut plutot etre positif, tu va plutot te coucher plus cultivé ce soir.
JP de Blainville.
