NOUVEAU ROTAX, 916-IS-A !
Post by VMF-214 »
Au ‘’Sun’n Fun (2023)’’, ROTAX introduit un nouveau moteur le : 916 iS… de 160 CV(ou HP) Puissance de Décolage et 137 CV(ou HP) de puissance continue en croisière!
Il y a un ‘’Video’’ dans chacun des liens Internet;
https://www.flyrotax.com/products/916-i ... Sun++n+Fun" onclick="window.open(this.href);return false;
916 IS A | ISC A | IS C24 | ISC C24
Puissance Maximale de 160 HP pour une minute et Puissance Maximun en continue de 137 HP!
Dynamic, turbocharged iS engine with best power-to-weight ratio, full take-off power, and a maximum operating altitude up to 23,000 feet.
• Four-stroke piston engine with four liquid and air-cooled cylinders
• Redundant electronic fuel injection and ignition, eco mode
• Turbocharger, stainless steel exhaust
• Dry sump forced lubrication with separate oil tank, automatic adjustment by hydraulic valve tappets
• Engine management system (EMS)
• Electric starter (12 or 24 Volt)
• Propeller speed reduction gearbox
• Intercooler
• TBO 2,000 hrs
• Maximum operating altitude 23,000 fee
ENGINE DATA
WEIGHT kg lb
Engine with propeller speed reduction gearbox i= 2,54 with overload clutch, turbocharger, intercooler, exhaust system 85.8 189
Engine suspension frame 2.0 4.4
External alternator 3.0 6.6
Air guide baffle 0.4 0.8
PERFORMANCE
117 kW 160 hp 5800 1/min
**101 kW 137 hp 5500 1/min
TORQUE
193 Nm 142 ft lb 5800 1/min
175 Nm 129 ft lb 5500 1/min
BORE
84.0 mm 3.31 in
STROKE
61.0 mm 2.4 in
DISPLACEMENT
1352 cm³ 82.6 cu in
FUEL*
min. MON 85 RON 95 min. AKI 91
Engine performance may vary depending on, among other things, general conditions, ambient temperature and altitude.
* leaded, unleaded, AVGAS 100LL, Ethanol 10
** max. continuous power at 5500 1/min
iS: ASTM compliant | iSc: certified according to EASA CS-E
ENGINE CONFIGURATOR
Set up your individual rotax engine with our engine configurator.
SELECT ENGINE TYPE
iS A — Approved according to ASTM F2339
iSc A — Certified to EASA CS-E (TC No.EASA. E.121)
iS C24 — To be approved according to ASTM F2339
iSc C24 — To be certified to EASA CS-E (TC No.EASA. E.121)
SELECT GEARBOX TYPE
Gearbox type 2
Prop shaft with flange for fixed pitch propeller. Suitable for simple airplanes.
Gearbox type 3
Prop shaft with flange for variable pitch propeller / drive for hydraulic governor for constant speed propeller. Possibility to operate the engine more efficiently and to adjust it individually.
Rotax Launches the 916
By Marc Cook - March 29, 2023
To absolutely no one’s surprise, the 916 broke cover today at Sun ’n Fun. Based on the 915, the turbocharged, four-cylinder, liquid-cooled 916 Rotax makes more power (160 vs 141 peak; 137 vs 135 max continuous) than its predecessor. This comes from a series of small adjustments, including a new exhaust system and revised engine mapping. More boost takes care of the rest.
For the most part, the 916 is familiar as an evolution of the 915. The key features are the same: It makes power from a geared, small-displacement four-cylinder design. It displaces just 83 cubic inches and revs to a maximum of 5800 rpm. The core engine weighs a claimed 189 pounds.
As with the 912 iS and the 915, the new engine uses a dual-channel FADEC (full authority digital engine control) that combines boost control, ignition and fuel injection so that the engine is truly single lever. There will be both fixed-pitch versions and ones that will accommodate a hydraulic constant-speed prop. There will be 12- and 24-volt versions available as well.
Sun ‘n Fun 2023: Rotax Introduces 916 Engine, CubCrafters First OEM
By Marc Cook - March 31, 2023
Rotax unveiled the anticipated 916 engine at Sun ‘n Fun along with CubCrafters’ announcement that it has built a new model, the Carbon Cub UL, around the engine. With 160 HP (maximum) and 137 HP (maximum continuous), the 916 is an iterative update of the popular turbocharged 915 and is expected to eventually replace it.
Marc Cook
KITPLANES Editor in Chief Marc Cook has been in aviation journalism for more than 30 years. He is a 4000-hour instrument-rated, multi-engine pilot with experience in nearly 150 types. He’s completed two kit aircraft, an Aero Designs Pulsar XP and a Glasair Sportsman 2+2, and currently flies a 2002 GlaStar.
Lien Internet : https://www.kitplanes.com/rotax-launche ... un+2023+#2" onclick="window.open(this.href);return false;
Voir, plus de spécifications ici-bas :
Lien Internet : https://www.flyrotax.com/products/916-i ... Sun++n+Fun" onclick="window.open(this.href);return false;
Mes deux cents,
