la main, sans ‘’Cales (Chocks)’’, ni attache(s) (Tie Down) et/ou frein hydraulique!
Visualisation d’un accident, due a un lancement de moteur à la main, sans ‘’Cales (Chocks)’’, ni attache(s) (Tie Down) et/ou ni frein hydraulique! Plus souvent utilisé, l’hiver!
Même, si le bon sens, ne requière que d’avoir au minimum des ‘’Cales’’ ou des ‘’Freins hydraulique’’ comme équipement. J’ai toujours, utilisez les ‘’Attaches (Tiedowns)’’ de l’aéronef et les ‘’Freins hydraulique (qui peuvent lâcher, n’importe quand!)
https://s30121.pcdn.co/wp-content/uploa ... erokee.mp4" onclick="window.open(this.href);return false;
Voici une ‘’Article en anglais’’ d’une personne que j’aime bien, M. Paul Bertorelli.
"One More Time: Chocks And Tiedowns.
By
Paul Bertorelli, Published: February 12, 2023.
In the publishing biz—mainly broadcasting—we have something called a PSA, a Public Service Announcement. You see these all the time when the station discharges its duty to keep the citizenry duly informed about stocking up on hurricane supplies, not driving through flood water and remembering to vote.
Think of this week’s video as a PSA. While colleagues Niles and Berge were holding down the balloon and UAP beat and having remarkable success, I was sweeping cyberspace for I-thought-we-knew-not-to-do-this videos. “This” is “Hand Propping” an airplane without a using chocks and tiedowns. Not either or “Both”. Yeah, I know, the hairy chested among us stand behind the prop and in the door to swing through. It usually works, but sometimes there are … issues. It adds “Some” risk. If you’re OK with that, you have been warned. (Hand Pro Tip: If it does get away, don’t try to hold a wing to stop it. Just call your insurance agent.)
As the embedded video, which rocketed around the web like a rubber check in a tile bathroom last week, shows, using neither chocks nor tiedowns invites disaster. And this happens three or four times a year (in the U. S. A.). Here’s hoping seeing this video will keep anyone from repeating the mistake. (The incident appears to have happened in 2020 and also appears to be cellphone video of a security camera.)
Voici un ‘’Vidéo en anglais’’ sur le sujet du ‘’Démarrage sécuritaire à main d’un aéronef’’, de M. Paul Bertorelli. À la fin du vidéo, ‘’Youtube’’ vous offriras, plusieurs autres ‘’Vidéo’’ de M. Paul Bertorelli, sur d'autres sujets importants.
https://www.youtube.com/watch?v=viiIBz1 ... jBRPiKCUUw" onclick="window.open(this.href);return false;
Bonne visualization,
Visualisation d’un accident, due à un lancement de moteur à
airpep
Re: Visualisation d’un accident, due à un lancement de moteu
Très instructif, merci.
Michel
Michel
Espérons que la sélection naturelle pourras être validée.
Que les a$$urance$ ne paierons pas et que ce crétin en aura pour quelques années à travailler pour défrayer sa niaiserie.
D'un autre ordre d'idée, la gagne de gestionnaires qui ont accepter d'avoir un stationnement
automobile à proximité d'un taxi-way aviation, sont allés à la même école que notre crétin pilote..,
Mon opinion...
Mon opinion...
