NOTAM (pour ne pas faire le saut)
- andreg00
- Modèle de l'avion: DA20-C1
DUE TO GPS JAMMING EXER, GPS (INCL WAAS, GROUND BASED AUGMENTATION SYSTEM AND ADS-B) INTERMITTENT LOSS OF SIGNAL MAY BE EXPERIENCED WITHIN RADIUS 162 NM CENTRE 440854N 753216W (MSS 230058) FL400-UNL, DECREASING IN AREA WITH DECREASING ALTITUDE TO: 162 NM RADIUS AT FL250, 118 NM RADIUS AT 10000 FT ABOVE GROUND LEVEL, 87 NM RADIUS AT 4000 FT ABOVE GROUND LEVEL, 39 NM RADIUS AT 50 FT ABOVE GROUND LEVEL. GPS BASED OPERATION(S) AND RNAV GNSS APPROACH SHOULD NOT BE PLANNED AT THE FLW AD: BROCKVILLE (CNL3) OTTAWA MACDONALD-CARTIER INTERNATIONAL (CYOW), CORNWALL REGIONAL (CYCC) INFORM AIR TRAFFIC CONTROL IF LOSS OF GPS SIGNALS AFFECTS ABILITY TO NAVIGATE. SFC - UNL, 20 MAR 11:39 2018 UNTIL 27 MAR 23:59 2018. CREATED: 20 MAR 12:14 2018
