ICOM, IC-A6, « HANDHELD COM Transceiver », neuf à vendre.
Je fais une vente de garage après plusieurs années en tant que Technicien d’Entretien d’Aéronef (TEA / AME). J’ai fermé mon commerce et j’ai mon restant d’inventaire à vendre.
ICOM, Model: IC-A6,
Portatif 760 canaux (Air) VHF Aviation portable de 118 à 136MHz, 5Watts PEP (1.5Watts porteuse) avec afficheur LCD et clavier. Espacement 25 KHz
Neuf dans sa boîte original avec garantie de compagnie pour 240.00 $ CDN. Taxes comprise.
ICOM, Model: IC-A6 “VHF Air band handheld transceiver”
Pilot Handheld (COM only)
Simple operation (One-handed),
"Flip Flop" frequency recall feature (10 Channels),
200 Memory channels (6 Character Alpha Tagging),
Side-tone function, with standard General Aviation headsets,
ANL (Auto Noise Limiter) reduces pulse noise,
Operation/charging from external DC power jack,
TOT (Time Out Timer) function,
Options: Headset Adapter (OPC-499), Lithium-Ion Battery (BP-221N) and AA alkaline Battery Case (BP-208BN).
Easy to use Simple one-handed operation is the most essential feature of the IC-A6. The well labeled, large keypad provides user friendly operation. The large display shows both letters and numbers and is easy to see, making for fast frequency recognition. The display is backlit, and so is the keypad. The light stays on until you turn it off – a very handy feature for flying at night. “Flip-fl op” channel recall The IC-A6 stores the last 10 channels used. You can easily recall those channels by pushing the “flip-fl op” recall buttons on the front panel. It is convenient for switching between several COM channels.
External DC power jack An external DC power jack allows for operation with the wall charger, BC-167S or the cigarette lighter cable, CP-20. When the battery pack is installed, simultaneous charging during operation is also possible. In addition, an optional battery case, BP-208N, is available. And more... • 25kHz channel spacing (Depending on version) • Water resistant construction, equivalent to IPX4 • 200 memory channels (20 Ch × 10 banks) with 6 character names • Dedicated 121.5MHz emergency key • Side tone function allows you to hear your own voice via an external aviation headset. • NOAA marine weather channels (IC-A6) • Tag scanning and memory bank scanning • ANL (Auto Noise Limiter) for noise reduction.
VENDU,
ICOM, IC-A6, « HANDHELD COM Transceiver », VENDU
Hélicopter
